Agghh! need some help on this one!
Was fitting my oil pressure and temp guages today, to i jacked the car up, droped the oil and removed the filter so i could fit my sandwich plate......
And there's already one bloody fitted! it takes the oil to my oil cooler.
i cant fit the plate on that because the filter will be to close to the ground.
But im lucky because there are to blanking plates that i can use.
But i need help in finding an adaptor to screw into the plate that i can srew the senders into as the hole is quite big
I have a trust oil cooler, and if anyone can find out the size i would be most greatfull! i have spent ages looking on the net but found nothing!
Or if anyone knows of a place i can send the blank to with the sender so that they can sort somthing out for me!
Why is nothing ever easy! :headvswal :headvswal
Hi
If I rem correctly there should be a 10mm bolt just above your filter you can screw your sender into. Or like my car remove the old sender from the oil way on the other side of the engine and use that. Easy on the ramp if you want a hand gimme a shout over the weekend
Craig
Hi
Craig
ahh.. i didn't know about the one on the other side, i got the plate due to having pressure and temp, if you available over the weekend and pasing by mate then i would appreciate someones advice thats done it beffore! how far away fro leuchars are you?
I'm about 3miles north of Dundee on the Aberdeen Rd. If yer cars mobile I've got a ramp in my garage standing under the car makes life alot easier. PM me your mobile number and I'll phone you later...
Craig
Craig
Im on this thing called QRA on base so cant leave for a week! she's on axel stands at the front at the moment, have you got any pics of ur presure sender fitted? (bit of a long shot i know!)
Not my pic found it on the forum new I'd seen it ages ago..
ace, i can probably fit my Temp one in there, any pics of the one on the other side?
