In memory of Mandy
Hard pipe kit install
Hi Guys,
Just got a lower rad hard pipe kit for the zed from danny at DTA. Before I start fiddling with the car has anybody here fitted one of these, if so is it str8 4ward get it installed.
Marc
Hi Guys,
Marc
Marc,
I included fitting instructions mate! :slap:
Danny
Thanx guys,
I have the instructions danny, just wanted to see if there was any other bits to look out for just in case I screw up something along the way.
Can the install be done easily from above the rad or am I better off lifting the car to fit lower pipe? Thats where my zed is losing water from.
Marc
Thanx guys,
Marc
You'll have to get under the car to attach the bottom silicone elbow to the rad (as well as when you drain the system) so best get the front in the air mate. Apart from what I've written in the instructions I really don't think there is anything else to look out for. Good luck!
Dan
Cheers Danny, if I get a break in the weather I'll get i done this weekend.
Marc
The rad part is quite straight forward. Jack the front up, drain the rad and swap the pipes. It is really is that simple.
