Faster Z
Which is the best way of making my z faster I was of thinking of a superchip?
[Clarkey, your Superchips comment has been moved to the moderators forum. While the background to your comments are understood, I would like to see CURRENT evidence of your statement. If you can provide this, your comment will be put back into your post. Thanks and apologies if the evidence exists. This is to protect the administrators.]
But, if you take a look in the drop down Z logo in the top of the site there is a section called "upgrade options" or something.
The upgrades are commonly known at modification "stages" starting off with intake and exhaust then ECU, generally if these are not done then further mods cannot be done. (edit - that doesnt read well, furthur ods can be done, just they will not give anywhere near as higher yield as they would)
So to start with you might want to look into getting a cone filter (blitz is recommended) and a new exhaust system (cat-back). These will set you back more than an ECU upgrade to start with but you will benefit more than just diong an ECU upgrade from the start.
Anyway as I said superchip are NOT recommended round here, the preferred chips are the Jim Wolf and SE chips. Im not too sure on the pricing of these but they are both very good chips.
[This message has been edited by Clarkey (edited 30-01-2002).]
[This message has been edited by moderator3 (edited 31-01-2002).]
