Lights Warning On Dash Perminetly On?
But how do you get rid of it, just done a lambo conversion.
I have searched but only found this from Vijay way back..............
I spoke to Luke @ the Z centre and he told me all I had to do was cut one of the wires. Just incase anyone else needs to know it was the red/yellow one on the row nearest the locking clip on the connector.
I've not got that colour? :confused:
Will it be OK if I just take the bulb out?
Pic of mine inc.
I thought you just had to insert a resistor in to the circuit to 'fool' it?
IIRC, it was a black box in the boot, is that what the pic is?
Vijay
Vijay
Pic is of the reverse side of the warning light cluster resting on the roof.
The wire is orange and red stripe in the pic (camera colour a bit out?)
have a look in the boot for a small black box under the drivers side rear panel, that's where the wire I cut was located.
Vijay
Just been out to garage and remembered half the car is stored in boot :wack:
I have looked where the wires in the picture connects to and funnily enough there is a yellow & red wire on the other side of the loom. Which goes to the cyan coloured wire in the photo, this cyan wire is soldered to .........the copper bit where the warning light for bulbs is. Am I on the right track, shall I give it the snip? :D
After fitting mine i tried snipping the wire as in the instructions , my N/S light went out :headvswal oops wrong one , re connected that and gave up.
I,ve got used to the warning light coming on when the lights are on , when there not on it lights up with the brake lights which at least shows you your brake lights are coming on :hyper: .
I never got any instructions with mine.
Think I will just leave the bulb out, although I am dying to snip the yellow with red stripe. :hyper: must resist........
I see people are still using search :D ;) :tongue:
Its great to be back :D
Cheers Andy, Its great to have you back :bow:
'I did search....honest :rant: :D :rofl:
Its not great to have me back - trust me ;):D Thanks for the compliment tho :D Search wasn't actually that easy - I also put my name in the search to narrow it down ;) Knew I'd posted about that before so... ;)
You can just take the bulb out, mine was like this when I brought. It wont affect anything else.
