Does anyone know if a series 4 N/A diff Without ABS option has gear teeth on the drive shaft for ABS sensor readings? :confused: This question is raised due to the TT axle's having port hole windows (as I assume the N/A does) where the axle joins the diff with a ring of teeth for the ABS sensors to read.
