I'm changing the spark plugs on my tt at the weekend.What do you recomend ?No fighting please !
I use HKS iridium plugs happy with result, also if your running higher boost use one grade colder plugs will reduce det/pinking i also have a set of Denso pk20pr-L11 platinum plugs these cost £8 per plug if your interested i will do you a good deal.
NGK PFR6B-11B are the ones you should be using.
Andy are they the colder ones as i have a boost controller fitted?
[sIGPIC][/sIGPIC]
