I have a problem, :cry: Ive got my left bank turbo seal leaking (bullocks)
I was wondering now ive got to replace one turbo should i do both? and should i upgrade and if-so to what how and how much is this going to cost this little dogy.AGENT MUNCH 008 :bow:
hi - come and say hello!
as far as the problem, speak to ryan@ ztech or mark @ zen garage. both have details in the traders section. they are both top blokes and can run you through all your options.
theyll need a little bit more info though ;)
If you’re going to the trouble of engine out and recon/replacing one turbo. You might as well do both. If one has gone the other won’t be far behind it mate. False economy to only do one.
Yep, afraid so. Its pointless to only replace one unfortunatly, especially with all the labour involved in taking the engine out to replace them.
Uprated tubs start at about £1200. Stock new tubs are no cheaper, but recon ones are.
Speak to Ztech, Zen or Southwestz. All in the Traders section of the forum.
In for a penny in for pound a?
£1,200. upwards ill start saving now. Still i wander standerd or upgrades. :confused: thanks for quick reply.
Thanks for the recommendations guys, give us a ring mate and will tell you your options and try to steer you on to the right course for your budget, we have a massive workshop in Lincoln so not too far away from you?
When you say it is leaking, do you mean the exhaust is smoking or there is oil leaking from the turbo?
If the exhaust is smoking the first port of call is to change the pcv valves and check you haven't overfilled with oil?
