Hello, I have tried to remove the medium-high rear spoiler, but it is still so stuck after removing the screws...any good advice?..
Hi dude. if your on about stock rear spoiler open boot take off plastic trim which covers wiper motor and make sure you have undone all bolts should come off ,you can use a screwdriver to lift it.
it will also be fixed with Mastik glue. Can be very tough to remove. Some have used Fishing line to cut through the glue in the past, other just use a LOT of brute force.
hmmmm a LOT of brute force sounds pretty much like something i would actually do
Did mine and yep the only way it would move is with shear brute force!!! Ended up snapping some of it in two though and bending the iron bar that runs through it but it came off in the end... Give it some welly!!!
