More problems (running)
Runnig problem when cold this time.
Had it about 4 or 5 times now, car idles fine no problem but when tring to drive I get the odd splutter and cough but no backfire out the zorsts. Only does it when started in the morning when cold i.e. left overnight. Only does it for around 2 - 3 minutes. Any ideas :confused:
CheerZ
Paul
Check the yellow ecu temp sensor for corrosion , mine was iffy and hessitated when cold ,i replaced it , problem solved . :hyper: BTW if you do need to replace it and struggle to find a nissan one , Lucas do replacements , work perfect :D HTH
Do you know the Lucas part number?
No sorry m8 , iv.e thrown the boxes away :headvswal They do both temp sender units , both together was about £12 IIRC Any good motor factor should get em for you :hyper: HTH
I have soldered the wires directly onto the temp sender some time ago because of corrosion so can't be that. Any other ideas ?
