Maximum Power
Hi Guys
I own a UK spec 300ZX TT manual. In the last 2 months i have purchased and in the middle of fitting the following :-
Greddy Profec B Boost Controller
Apexi BOV's
Greddy FAT Turbo Timer
Greddy side Intercoolers
Smithy Under Drive Pulley + Belts
Hard Radiator Pipes
Hard Turbo Pipes
Koyo Radiator
New water Thermostat
New Water Pump
Greddy Radiator Cap
Carbon Fan Cover
Oil Filter
Greddy Oil Adapter
Gauges + Sensors
New Oil Pressure Switch
3 POD Pillar + Gauges
Mocal Oil Cooler
Blits SUS Induction System
De-Cat Pipes
New Oxygen Sensors
RPS Max Clutch
RPS Flywheel
RPS Pin
S.S. line
Short Shifter
Energy Systems Poly Suspension Kit
GetGreddy ECU
Iridium Spark Plugs
Grounding Kits
Now looking to future. Next engine mod will be new turbos. Planning on keeping standard turbos for a bit as they have only done 2000 miles.
My question is, i am thinking of uprating to JWT Sport 530 Ball Bearing Turbos w/ Downpipes + a set of 555 injectors. will i need to replace engine internals? The engine is new and only done 2000 miles? Or what PSI could i run before i need to fit new pistons etc?
What sort of power should i expect to get with what i have fiited so far on 14 psi. Both at fly and rwhp?
What power would i be looking at with new turbos & injectors. Looking for big-ish power if pos with turbo whistle.
Thankyou for any help
Kevin :bow:
if your upping the boost youl need forged pistons or you will make that engine a grenade.
Greddy do decent upgrade kits, but i wouldnt do it if you have stock internals.
Yes, if you want the best out of your tubs
360 ish fly 300ish wheels
not a question of power with stock internals, more of a question of how long the internals last, candle that burns twice as bright lasts half as long :nelson:
I have standard tubs and internals. Only engine mods are JWT Chip, boost controler (set to 15.5psi) RPS clutch, Blitz filter, de-cat. I got 325bhp at the rear wheels (400 at flywheel) on Thore's rolling road.
You should theoretically achieve a higher bhp than me because you have more engine mods like lightened flywheel etc.
u serious ...with those mods !!!!!!! :confused:
Yes m8 I'm serious. 324.6bhp at the rear wheel to be precise. The torque is the best part 342.6ftlb at the rear wheels!
Attached is the rolling road print off.
