hid bulb question
Does anyone know where i can get hod of one of these hid bulbs?
different as the wires are connect to the bulb fitting as one unit, the ballast boxes are hella
If your ballasts are made by Hella then I'm pretty sure our X5 H.I.D. bulbs will fit. I'll ask my supplier and get back to you.
Cheers,
Dan
Cheers,
Dan
cheers if you could as my customer is getting deperate for his car back, is the wire connected to the bulb though
Yes it is (see attached pic). The white and black wires are attached to the bulb and go directly to the balast (disregard the red/black one - these connect into the lighting wiring loom). In the pic the bulb is encapsulated in a protective cover (brown plastic) so don't confuse that with the actual bulb.
