damn im so fed up my z now seems to have developed a dislike to curtain junctions and stalls this is getting a bit embarrasing.
when does it stall? when slowing to a stop or pulling away?
when you go to change down approaching a junction so slowing down :headvswal
Do you have an aftermarket boost gauge fitted?
If you have, you can check the vacuum reading at idle and as you change down and brake.
Find someone with conzult and connect to check the aac valve duty.
Is there any change with the a/c on or off?
Steve
Steve
hi steve my z is a non turbo so no boost guage at all .
don't think there is anybody local with a conzult (that is a plee to the masses by the way ;) )
i thought it was a bit better with aircon on well it happened less frequently thats for sure
pop over to z-tech mate,check it on the consult FOC of course
This happened to me.
Ended up being my TPS. try cleaning it and repositioning it.
I's say TPS as well, but since you've not had any engine work done it seems a bit strange. Could also by your IACV, maybe it's dirty/clogged after being at the bodyshop
thanks allot guys i have taken all the info in and will have a go
greg do i have to book an appointment for a conzult check buddy
nah mate pop up when your free :) just ring before! so someones there,
wow cheers fella what time do you guys work till on fridays
there from 8-4ish mate
