Annoying rattle
seems to come from front right of car - apparent when going over bumps it sounds like plastic squeeking together and is quite loud.
I know breakdusts car makes the exact same noise as mine and wondered if it is common? My suspension is brand new so i know its not springs or shocks.
Even when you shut the doors its enough to cause it to make the squeek its beginning to get on my tits :headvswal
Anyone help me out :confused:
could be you bonnet hinge mine has the same problem ....grab hold of the corner of the bonnet at the window screen end and wiggle it if there is excessive play thats tyour probelm ... a temp fix is to oil it up. a semi perminent is to take the hinge off and gently tap the rivit with a hammer ..my fix is to buy chrome bonnet hinges lol
oh and another which some of the others have had was the bonnet catch which you need to adjust the rubber stops to stop any movement
hth
gaz
Cheers for that ill give it a go. Interesting you say it could be the bonnet..... It does bounce around ever so slightly when driving but I never associated it to the noise. It might just work :D
Hellraiser you are a star your diagnosis was spot on mate :D As soon as i popped the bonnet the noise stopped :D :D :D
