Indicators not working...
The indicators on my car have stopped working. The hazards work fine and the flasher on the indicator stick works fine.
I think it may be a fuse issue but am not sure what fuse I need to replace? I could not see a fuse(s) for the indicator under the bonnet in the main box, or have I over looked something?
One thing to check is the hazard switch as the indicator feeds go through this, it may not be resetting correctly after use,try the normal indicator with the ignition on and then wiggle the hazard switch to see if they work then. Jeff TT
I am assuming that the 'Turn Signal' is the probable fuse for the indicator.
CheerZ,
Andy
Changed the fuse, and all works fine now, but when I indicate left all the indicator lights start flashing. When I indicate right only the right-handside lights flast which is correct.
Help!
As I said before check out the hazard switch sounds like a fault there to me, probably what took the fuse out also.
Jeff TT
