Lumpy/hesitating when cold
When I start the car on a morning, no problems and choke is working fine.
After maybe half a mile, it's as if the choke has gone off too early and runs like a bag of shite. After maybe 5 mile, when she's hot, it seems to be fine.
Any ideas?
Steve
Hi Steve.
I have a similar problem but mine cuts out then starts again and runs fine til the next
time its cold then same again,a few places to look as you may allready know are,
tps connector /temp sens con/ maf con/ptu con/ I would go for tps and temp sens
connectors first.
Do you have any fault codes?
Hi Steve.
connectors first.
ECU is code 55 OK
im have simular probs with mine when cold im watching this thread for developement but probably get replys to search faqs ect.
most hesitation is when its warm people put it down to ptu... this one i have found to be quite unusual. i suspected a lazy o2 sensor messing up the mixture but i got told these dont kick in until 2 mins after starting so not sure.
Mine used to hesitate when it was cold ,i replaced both temp sensors and that cured it . :hyper: :hyper:
