Mirror unit electrics - where?
Im in the middle of replacing my passenger side wing mirror unit. I have the old one of. But where is the wiring for the new one - do I have to remove the door card to get at it?? Or does it run in under the dash? Thanks for any help.
Nuts, so I gotta go pull it off so....
Can anyone recommend a breakers yard where I can get a wing mirror. The one on my passenger side does not fold in when I use the button.
check under the glovebox on the very left habd side there are some connectors which can work loose push them in and try again.
mine had the same problem wiggled the connector and it worked straight away.
give it a go
gaz
The mirror moves a some of the way and then gets stuck, seems as if maybe some of the teeth in the motor are missing or something.
sounds like a dirty connector its very unusual for a motor in th mirrors to break methinks! i still recon its a connector somewhere.
i would take the door panel off and connect the connector inside the door to a direct 12volt power supply to test it.
if it still doesnt work replace.
all the best
gaz
