Antilock light on!!
My Abs light is on, and has been for some timw now, Where should I be looking to find a problem, or is there a check i can run to find a problem?
I ran an Ecu check - nothing coming up.
Cheers.
low brake fluid?
No, checked it cos I did the pads last week, the light was on way before that.
sensors, one on each disc, detect rotation of the wheels under braking, usually get covered in crap, clean them and it should clear
I take it I have to remove the discs?
What do the sensors look like??
Thanks splatt ;)
same thing happened to mine i think if you reset ecu by disconnecting batt for about half an hour or so should be sorted as long as evey thing else is ok.
Thanks splatt ;)
no mate, get the wheel off and remove and clean the sensor. clean all around with an airline but dont get too close and point it away from you!!!
  • 5 months later...
my light is on too and i`m going to take the lot off to check sensors i took bty off of 12 hour light still on prob because the problem is still there so the wheel will have to come off. any other ideas if this is checked and the light is still on any checks that can be done with the abs pump...
