boost numbers?
hi all, i have the apexi digital boost controller in the car and its set at 0.9 bar for everyday use, when i was driving home tonight, booted it and its only going upto 0.6? and not upto 0.9
why is this, do i have a leak?
cheers
HMM might be on safety boost does the power feel down?? try an ecu diagnostic
yes it came up with code 33? i reset the codes and it now just coming up with code 55 which is all syestems ok for now....
matey here is a link to tell you the codes and what can cause the problem. Not sure if you know them already bud ;)
http://www.ttzd.com/tech/diagnostictech.html
[sIGPIC][/sIGPIC]
i'd say safety boost but usually the solenoids are disconnected when a boost controller is added, not sure what code 33 is, but 34 is det sensor circuit which would cause it to go in safety
cheers clarkey, ive started another thred by mistake..
