October 24, 200520 yr ive checked my car and i am pretty sure it is stuck in the safety boost the needle does not go further then 7 psi, i have no idea what i am supposed to do. :headvswal need some help and direction to sort it out!!!!!!!!!!! :headvswal
October 24, 200520 yr What fuel do you put in? Optimax or Normal Unleadded. basically you need to do the following really. A: ECU Diagnostics Check to see of your got det sensor problems. B: Boost Leak Check, to make sure its not loosing the pressure. You can bypass the det sensor quite easily if thats the problem, downside is you car wont pick up on detting.
October 24, 200520 yr okay i need to start using optimax my car is getting a diagnostig check this week how do i do a boost leek check and sorry but i dont understand anything about the det sensor, what do you mean it wont pick up detting????????????????????
October 24, 200520 yr Easiest way is to find somebody with a boost leak detector, you have to pump air into the system with the engine off and listen for leaks from all the hoses.
October 24, 200520 yr Possibly Mark (Topless) at Zen garage in london or Ryan (Baggins) at ZTech in Swindon. Best put a post request up and see if anybody near you come forward :)
:headvswal
