oil temp & pressure gauges
Hi please help.....
Where is the best place to mount an oil pressure sensor and oil temp? :headvswal
The easiest way is to fit a sandwhich plate between the oil filter and housing,Chris at Get Greddy can supply Greddy ones, dead easy to fit , it has three take off points but depending on which make of guages you are using , you might have to get the holes re-tapped to match the threads of the sender units, i did, mine are Autometer Guages.HTH :D
the thread is not that uncommon. I PRO LED gauges and it was a straight swap with my stock pressure sender.
