protoj · Yesterday at 18:48 1 day
Hi folks. Hopefully some of you will be interested in this. We're planning on having a bit of a Go-Kart session in Crawley on the 12 November and trying to get a few clubs together for a bit of friendly competition.
Stick your name down if you're interested.
I'll keep the list of everyone attending HERE
