bleeding brakes help !!
Just about to chuck on my R34 brembo's , fitting shouldnt be a problem but the bleeding of the brakes is that i have a question about. I have the manual that states order to bleed in then it says " front side air bleeder on the abs unit then the left side bleeder on abs unit. Where abouts are these on the abs unit and is it totally necessary ??
cheers
abs unit is in the boo matey!! and tbh i dunna think its necessary if its for the fronts!!
lol.. i mean boot... ( stupid keyboard )
im changing front and rear bud , and i know its in the boot but where on the abs unit itself are the air bleeders??
Ya cana miss them once you get the cover off there looking to you .. I have heard some of the later J specs don't av em but dont hold me to that
Craig
Karl give me a call if you want some help, or bring it over and I will point out your nipples :eek:
well on mine they are under the righthand side cover where the rear speaker is!! and its normaly coverd up with sound proofing! and the 3 "nip's" are onthe top of the pump! 1 for back, 1 for FL and 1 for FR..
But where are they on the SWB?
Are they behind the drivers seat? As ive just fitted new brakes on mine and alltough theres no air in the system im still getting a spongy pedal. :confused:
yep behind driver remove the curved plastic cover its sat under sound proofing material ;)
Must remind myself not to post until I have read all the replies :nelson:
