alloys - will they fit
OZ Racing 9 X 17 Front with 245/40/17 11 X 17 Rear with 275/40/17. Off a Toyota Supra. Reckon they will probably fit but will they be too big? Would like to try but am not going to get much opportunity. Any one running anthing like this.
Offset on the Supra is 50, so being the size they are would probably stick out quite a bit:D Also the front hub centre is a different diameter (smaller) you can reverse fit 300's onto the supe but unless thay have centre push out rings fitted you cant do the reverse.
Saying that alot of supras seem to run incorrect offset wheels so you may find its OK! Only way to tell is to try i'm afraid.
Roy
Cheers. You obviously know your stuff - or at least a damn sight more than me! What other cars take the same fit wheels as a Zed? I keep looking in the classifieds hoping to find a reasonable set at a good price but you get many wheels advertised for a Zed - now there's a funny old thing.
Cheers John. Got that Zed resprayed yet? I have been looking for a good turbo manual but everything is always too far away. If they are anything like the ones I looked at before buying the N/A then I'm afraid someone else's idea of mind is not mine. Need something local.
I only know due to fititing my old Z alloys to the supra. TBH depends what your after, they share the same PCD and most alloys use a push out rim on the centre so hub clearance is not an issue. The problem is that differences in offset will effect how it handles. Also incorrect offset wheels may foul the calpiers! Handling may not be noticeable during road use or may tram line like a bugger.
No mate not yet!! Just gone for a bit of a performance upgrade after going out in Royal's car that day!!! Now running at 1.1Bar boost, and just added a Kenlowe electric fan to get rid of the Viscous one and added some blow off valves too boot!! Respray comming soon though when my mate gets his arse in gear!!! :D
