PCV Hoses
:confused: Got the two valves and hoses from Nissan. The two hoses are the same, parts man says the part numbers have been merged into one. Only thing is, it looks to me that the passanger side hose should be of equal diamater at either side as it does need connect to a small pipe as per the drivers side.
Could any kind soul shed some light on this for me please.Cheers :confused:
passenger hose is differant to the drivers
drivers side is small one end and the other end is equal diameter of the pcv valve
passenger side is same size both ends IIRC
;) Cheers greg, thats what it looks like to me, parts man was addiment on the phone, i'll go up and chap his door tomorrow
:confused: Did you only get 2 hoses ?? should be 5......:x:
Just doing the essentials at the moment, i knew the ones at the valves would be brittle, will get the other three soon.
Cheers Buddy
Cheers Buddy
:D Good thinking Batman......... ;)
Looking at the set of parts I have here, you should have :-
11823-30P01 Hose Evapo
11823-30P10 Hose
Which, IIRC are the ones that fit onto the valves themselves. Then there are :-
11823-30P11 Hose to co
11823-40P01 Hose evapo
11823-40P11 Hose evapo
Which are the slightly larger, thicker & longer pipes.
