Hi,
Gonna hook up a Conzult and sort out my intermintent idling problem. What I need to know is exactly what sensors affect the idle so I can see what they are doing.
IAA unit
Air regulator
Temp sensor
TPS
Hi,
IAA unit
Air regulator
Temp sensor
TPS
Hi Vijay,
What problems are you having?
You can switch the aac valve to manual operation and operate it using the scroll adjustment from 0% to 100%. You should notice the idle increase the higher the aac value.
Make sure the TPS is set at 0.44v and that the idle switch is on. The idle switch should turn off when you touch the throttle.
Temperature sensor should be reading around 80c when at normal operating temperature. Try moving the connector to see if a bad connection changes the temperature reading.
Aside of the consult tests, try the usual cleaning of the throttle bodies and efi harness connectors.
Steve
iwas going to say check for boost leaks,but as vijay is king boost leak detector seller :D im sure its been done already
not often needed to but if you have problems with the IAA unit
Idle Air Regulator (IAR).IAA This valve lives on the the intake manifold, above the passenger-side Its temperature sensitive open when cold, closed when hot. That makes the car idle higher when it's warming up,cleaning of the yellow and blue connectors at the back of the iaa unit may help
im sure theres an article on TT.net on removing and cleaning IAA unit,might be worth a shout if all else fails
Hello guys,
The problem is the usual sudden high idle. I just wanted to hook up the Conzult and see what the senors were doing when the idle shot up :)
Vijay
have you tried looking for a vacum leak, that is what was wrong with my erratic idle.
closed position switch???
TPS.
Check it is set at 0.44v at idle at normal operating temperature.
Above this setting, the ecu thinks the idle switch is off and increases the rpm accordingly.
Steve
Cheers Steve, know what you guys mean now :)
Vijay
