HID Conversion
How may of you have fiited HID lights
1. With the wiring conversion that alters the on off sequence. Mainly affects when you flash someone
2. Straight HID install leaving the switching as it was.
Mine is straight out of the box as well, to be honest I dont feel the need to use the main beam anymore as the dipped is brilliant.
Arrrrr, but what happends when some koont comes the other way with his full beam on?? You've got to the gentlemenly thing, and FULL BEAM him :D Which then switches over your lights ;) This way they get ALL the lights on at them :D :cool:
Too right and i just happen to be shifting a H1 set in my section ;)
Yeah I know, may change the switching over when I get a weekend free, then going to fit HID to the main beam as well to make up for all the people that got away with leaving their main beams on and trying to blind me. :D :D
Looks like the switching conversion is not so popular
Anyone else done it
Might have ago
Ill let youll know how I get on
When you go from dipped to main the dipped goes out, if you change the switching then you can get it so they are both on when your on main beam, the reason for that is a HID bulbs life is shortened by turning on off .
Anyone else done it
Might have ago
I was going to do that with what was already suggested which was to ground pins 4/5? Only they seem to have some sort of power running through them and the last time I tried it my battery went dead completely. ¬¬!!! How ever, seeing as no one has found this... I think here's a nice doc which apparently is the 'right way of doing it'.
Seeing as I can't upload the thing cause it's too big I'm hosting it myself. It's not always gonna be there so get it while you can... or try find it yourself as it took me fackin ages to find...!
>>> CLICK HERE TO DOWNLOAD
WTG W1NG!! :bow:
Yay, someone has translated the Japanese :D Yep 'Thats' the proper mod. Unless your a registered member on the Jap site, you can't get to see the whole document, and has anyone tried to be registered? I did, and it doesn't work :confused: I don't know why, I tried about 6 times from different PC's and got the same thing everytime. So anyway I'm glad you've found that :bow:
ah, so if you install it as standard it still works like the normal lights.
by how much would the bulb's life be shortened without the switching mod?
Yeah as you say Dave thats the one
I picked that up from the AUS300zx link no problem
It is simple electronics one relay one zener
Also the HID system will draw less current than the std bulb so it shouldnt be a problem to run main beam + dip. HID only draws higher current when switching on so this mod is really helpful.
Anyway you wouldnt have it on for any length of time as you say Dave.... its mainly to blast people who are complaining and flashing you. :D
WTG W1NG!! :bow:
......Unless your a registered member on the Jap site, you can't get to see the whole document, and has anyone tried to be registered? I did, and it doesn't work :confused: I don't know why, I tried about 6 times from different PC's and got the same thing everytime. So anyway I'm glad you've found that :bow:
Yeh, I've tried to register a few times but it never seems to work. :headvswal
