Smoke came out of window vents??
I was driving the Z the other day when a small haze of smoke just trickled out of the vents in front of the windscreen on dash?? I pulled over flipped the bonnet and nothing :confused: it only happened for a few seconds, misted the front windscreen then dissapeared?? Does anybody know what this might of been?? Cheers. P.s no other vents just the front windscreen ones.
heater matrix i expect, check your footwells see if they are wet.. if they are wet or damp then the matrix is about to go.
exactly same happened to me , check the rear 2 rubber pipes that go to the heater matrix , mine split on a motorway and and steam covered the drivers side of the screen , couldnt see anything !!
I dont suppose somebody could post a pici please. ;) It could have been steam. :eek:
no pic bud back at the very back of the engine bay in the middle u will see 2 metal pipes leading inside the car , This is the inlet and outlet of the matrix water flow, its the 2 rubber hoses connected , one on each pipe that went on mine.
Cheers bud much appreiciated. ;)
