ebay converters
hi my clocks r in kph and theres some well i dont no replacment dials r they easy to fit i can get the clocks out but then i get stuck how do i get the glas of to change the dials look tricky dont want to end up with no clocks and how come my car say 180 kph thats not fast for a zx is it
or what about this on ebay is it hard to fit 4582187522
this is the dail 4582790570
If I may be so bold.
English lessons might be a good start. Try making some sense and you might get on better. :-)
As for the dial, it only goes upto 120mph... DON'T BOTHER!!!! I see no point in bothering with this, as the proper dial should read upto 180MPH.
As for the de-limiter, not too bad a price, and it should come with all instructions.
As for getting the clear plastic off your clocks, you need to remove the two screws at the bottom of the rear of the clock assembly. These scews are attached to two metal strips that take the power to the four lamps in the underside of the unit at the front. Once these two screws are removed, carefully pop the black clips all round the joint (between the black and white sections), now slide the front section off the clock assembly. As for changing the clock face you'll need to remove the needle first, be very carefull.
always one markstevens if you cannot leave a poss comment then dont leave one i wouldnt insult you for no reason would i if you dont know the answer or do not know what im talking about ask me to explain dont insult me better to just say nothing i dont need people like you messing up my day dave gave me the answer i needed no prob so please markstevens leave me alone or i will report you to the modarator
:nelson: And only 34 posts!!!
please let me not insult you but to come in to a club after posts
34, and leave a Snotagram!! is not the best way to ask for peoples advice.
The folks on this forum have a great deal of Knowlage, mainly by
the expence of themselves, so a bit of advice to you old bean.
Ask your questions clearly, if you wish to get people to look at something for you , please put a link rather then just an ebay number. I for one would not wish to find the product on Ebay just from the ad number.
If you need help make it easy for the helper to help you! ;)
Also when receving a reply try to bite your toung as there are some
;) ;) ;) replys
Shame you got off too a bit of a bad start but i will try to help you
if you put up some links
Thank you for understanding
Allan :)
Yep, Take a look at http://cgi.ebay.co.uk/Nissan-300-ZX-180-MPH-Speedo-Face-Dial-300ZX-Non-Turbo_W0QQitemZ4581732073QQcategoryZ10402QQrdZ1QQcmdZViewItem
I beleive that is exactly what you are looking for.
Then have a read through http://300zxclub.com/showthread.php?t=24119&highlight=led%27s, especially post 23 on that page, well worth reading before you start to change a clock face.
