New big wheels
I just bought this morning the Volk wheels on the link below:
Volks wheels
I've already pay for them but now I scare that they will not fit my car...
The wheels are 10x18 all four with 255/35/18 tyres on them and ET 5.
I'm sure the rear will fit perfectly but the front???
Do you think this will fit?
Thank you
i cant 100% say the rears will be fine but 10" on the front might be a bit to much most have 8.5" maybe even 9" but 10" :confused: ride might be a bit ruff LOL
Peach had 10x18 all round and it was fine, just make sure the offset is correct!!
And did you buy them from Mike (dragonoir)
If yes, say how do from me please :)
I cant read much of the site you show on the web
If the wheels come from a Jap car Honda / Mazda / Nissan / Toyota and are five stud then the pattern at 114.3 pcd will be ok
As for the offset 5et youll just have to try
Good luck
and give my love to Paris
lol
Yes I bought them from Dragonnoir.
They come fron the Nissan HKS S15 that they bought in Japan to initiate the Drift in Europe.
And I bought this wheels :D :D
yep I reckon 10" up front is a bit too much, still I can imagine those looking pretty damn awesome especially under flared arches all round :D
these offsets are are bit low mate i think you will just about get away with the front i run 8" on the front with a 25mm and a 6mm slip on spacer with a 35 offset wheel thats makes it a +4 offset the wheel sticks out a bit but could come out more.i run 9" on the rear with a 20mm spacer with a 35 offset wheel that makes it +15 and they are flush with arch a have a slight roll on the inside of arch to stop them rubbing .i think you are going to need an arch roll and probably a arch flare .Flares involve pulling arch out and normally cracks the paint .see getgreddys sig pic of red drift car rear arches that is a flare .if you can get them to fit they will look cool drift look maybe strech a smaller tire size on to help clearance 235 .if you stuggle with the rear use adjustable rear upper arms to camber the wheel into the arch good luck mate i would like to see a pic then fitted.
Ok thank you.
I will be back in France the 15 of November. Then, I will have to fix my engine and then I will fix the wheels.
I planned to do a full paint job so I may do it sooner than what I was thinking.
what offset on the rear mate they must be fairly high et +30 to +40 have you got standard arches on the rear .
Does anybody know the offset of 10x18 Volks Ray GT-N ??
I think you'l find that she'll tram line real bad. No problem on smooth roads but tram lines, white lines, subsidence and any uneven road surface and your stearing will be pulled all over the place.
Keep off the white lines at speed. (Scarey!!!)
Also they most likely shread your inner wheel arches.
P.S.
Those wheels. "Mangnifique".
They have come of a R33 which has the same offset as the Z32 so off set will not be a problem though what I said before I'm sure will be.
If you have problems with the front wheels then How about Sharing the cost of buying a set of 8.5 J to the same spec and design and you could sell me a pair of the 10.0J so we both have a full set. :D
Seriously if it is a problem I'd be up for that.
That's a really good idea.
2 wheels in 8.5x18 should not be so expensive I think.
In one month, you will receive news.
This car will be only for Drag racing and Drift
They are looking for people in France to Drift :D :D
  • 1 month later...
So I'm back home and they won't fit.
Thay fit but there are going 3" outside of the car :(
Hi Bubuche
How do the rear wheels sit? Even if they are 3" too wide for body that is OK with me. You tell me what pattern they are and I'll enquire with Chris at Get Greddy how much and how long it would take to get them in 8.5J with the correct ofset. If your still interested?
Where abouts in France are you?
PM me with your address etc and I'll find out courier costs etc for drop of and collection. you can Email me some pictures of just how they sir to markgrenner@hotmail.com
It may well be cheeper to bring them over and collect myself. (Any excuse to take my new Navara over the pond and fill her up with good wine :D )
