gurgling noise
Im hearing this gurgling sound coming from the back of the engine
right in back of front wheel arch on the driver side . im right hand drive.
i only hear it while idling ..
doesnt seem to affect performance
but sound awfull im planning on taking tire off remove the plastic covering
and hopefully see something that can be fixed .. any ideas before
i venture is appreciated..... thanks./.... :confused: :confused:
:bow:
wonderfull .. ill try and drain the water ... thks pal... :bow:
:bow:
just be aware mate that they'll sooner (rather than later) just fill up again. i drained mine out and 3 days later it was gurgle gurgle again. better to remove or (easier) to drill/block.
could someone tell me what the AIV's are and what they do?
Spent about 2hrs saturday removing wheel and getting to AIV
not so hard to get at,, anyway drained out fluid .tried punching
a hole into hose so any more would drain out ..
seems maybe the hole i punch wasnt big enough , so this
morning i listened and sht... gurgling is back ...
ill make another attempt making sure hole is big enough
i dont want to remove AIV seems more work ......
..... :headvswal :headvswal :(
