just noticed i have a problem with my interior light, inoticed on monday the interior light stayed on after i had opened then closed the door, the door open light on the dash also stayed on but dimmed when door was closed, took car out aftera about 15 mins running the interior light went back to normal and i could hear the relay click (which i could'nt before) so just parked car up and left it, just got home and noticed the alarm led was not on so got keys,and i've got a flat battery on further inspection the boot light was stuck on any ideas is it just the main interior light relay or is there another one for the boot light? thanks for any help in advance kev
Just been looking through the on-line manual for you (HERE ) and the only other thing I could think of (other than what Paul has put) is that you could have a dodgy relay unit. But certainly check all three lamp switches and see what they look like. The door ones simply screw off, cant remember what the boot ones like.
could be as simple as your door latch needs adjusting, that's what happened to mine when it came out of the bodyshop :)
Vijay
