up & down
what can cause an eratic idle guys my car idles eraticaly all the time when warm, sometimes it idles normally bout 900 rpm then other times it can go up to 1500rpm and other times as low as 600rpm which makes the car shudder due to the engine barely running it goes up and down like a yo-yo when im in a traffic jam i will have stopped the car idles at 1200rpm move 1 car space take it out of gear and down to 600rpm its really doing my head in can someone help ???????
jim zx
No free traders
wheres the best place to get it sorted pal your from kent do you know any places round here ??
well im taking it to z-tech on tuesday im already gonna be spending about 700 quid if its what u think it is how much do you think it will cost to get sorted ??
iaa unit is one but it could be a few things ajusting the base idle wont cure erratic idle,if you have an auto and the revs drop as soon as it is put in gear,might be worth checking the TPS is set to around the 0.40-0.50v mark,clean connections including injector connectors as you may be missing on a cylinder causing the car to run odd!consult is a good place to start,as this will show up the main signals from the ecu,your welcome to pop over to z-tech which aint a million miles away based in wiltshire,we can perform a consult for you FOC and can do a boost leak test ;)
ring ryan@z-tech on..07968166640
greg
LOL reread your coming up anyhow :D
i been tryin to find a garage in kent that does zeds cheers mate im sure ill see you soon
yeah see you soon lol
well i wont get a chance before tuesday when i go to z-tech so ill just get them to do it but the car needs a bit of work done on it clucth and other bits so ill probably see you in the near future cheers pal
