FAO Electrical Whizzos
Hi all,just been out in the rain and went to
turn off the ignition and it ran on for a
couple of seconds and the ariel stayed
up and with the key out of the ignition
the boost gauge goes up and down and
all the hicas abs battery lights etc come on
dimly then go off then on.It sounds like
a short but any ideas where to look.
bubbles
It sounds like water ingress
Im no expert on the ZED but I wonder if that fuse box up by the drivers corner of the engine bay ever gets wet...windscreen washers are around there as well !!!
If youve got a heat gun (they are great £20) blow hot air on all the likely places you can think of or see water
then spray with WD40
If the problem goes away
Seal the leak
Just one more idea Bubbles
Love your 19s
Possible dead battery caused by dead alternator?
