stereo experts ..help needed !!
Had one of those kenwood dvd headunits with built in 7.5" touchscreen fitted and working was fine, then this morning , there is a message on the screen saying : Disconnected cable found - Please confirm a connection line . Ive checked all the leads seem to be ok but also noticed my amp in boot wasnt on either , checked the inline fuses on the amp and on the amp itsself and they are fine , Amp is earthed fine too but still no lights on it . Any ideas ??
have u checked ignition live to the amp ?
is the remote lead (usually the blue one) deffo connected at both the h.u and amp?
the amp is wired via zero guage to the battery and fuses are fine , earthed fine but when stereo is switched on the message appears but not sure if this is stopping the amp coming on , need to do a voltage meter check i suppose dammit
deffo connected to the headunit and amp yeah , i traced the leads back so im baffled damn thing
checked the wires to the hideaway unit ( brain ) and seem ok too ??
theres a little reset button on the left side of the system use a pin press it once or twice and it should reset
try yer amp direct to battery ( with inline fuse of course ) might be dead :(
did that bud no change
Try disconecting the Main leads to the brain then reconnecting. also try disconecting the mem and live wire to reset
what model head unit is it mate
must be something in the air ???? my kenwood has packed up to.
Have you tryed giving it a bash mate :D
take it back to the installers to sort out if they're not too far away mate.
ok stereos are a problem in the zed then just fitted a sony unit worked for 2 days and has now stopped all wiring is ok amps still work but no door speakers
its the kenwood dvd725 same as this one http://www.incarexpress.co.uk/view_product.php?partno=KVT725DVDB
Ive booked it back into the installer for thurs so il soon know whats wrong.
Karl
turns out the headunit is fooked !! and its brand new !! installer checked all wires ect and now kenwood coming out tomorrow to take the unit and check it out , promised a 7 day turn around and will collect and deliver f.o.c . but how pi55ed am i !!!
Change it for an Alpine ;)
make sure you get the serial number of the unit, that way you can make sure they dont just try and fix it and palm it off on you when they return it, you can check it then to make sure its a new unit
if the unit is within it's first 30 days from fitting you can demand they replace it not repair it but unfortunatly after that 30 days it the manufacturers descresion as to weather they repair or replace the unit
