Single Din dash pocket
Is there such a thing as a single Din pocket for the centre consol of the 300ZX.
Ive got a single din head unit which fits ok in the slanty top or bottom but that leaves me with an empty slot which I would like to fill with a pocket any Nissan options ??
ALSO .... Cmon You head bangers ...wheres the best place to fit a subwoofer in a SWB ??
  • Replies 26
  • Views 979
Yep, they are available...Z centre might do one (do everything else) otherwise they do come up second hand sometimes!!
Mine's gonna be going centrally in the boot, careful placement means I'll still be able to get me Targas in as well. I'll post a pic up tomorrow.
yep, i got mine from a car audio shop. they had a fitment list. think it was a standard nissan one. bout £12 i think.
hth
nick
The single DIN pocket is available from Nissan, and if my site is ever resurected the part number is on there ...
like this mate ive done something simular for a 12"sub sounds good and can still get the targas in
Cheers Guys
Thats me sound sorted
Might get one of dem nuclear waste containers (base tubes) that Halfords sell, you know with four plastic (metal) rods
...nah !!
Think of all the times Id get pulled up
Would you explain what that is in your boot sir
Cheers Guys
...nah !!
any one used or seen one of these used? i have the RCA's and power cables lined up just nothing to plug them into yet!
Hey Gaz
Whats with the 20 inch Beemer wheel ?
Is there a car attached ??
Nice bass machine....booom booom
heres my sub box with a 12"mac audio 300 sub in it
hth
gaz
Most of you Zedders seem to favour the far rear quarters for big bass.
What about behind the front seats I have SWB remember..The clearance is only about 30mm between the metal plate and the cover, but I could increase that by 4 inches without any great sacrifice.
Or theres the centre tray behind the two front seats
It would leave my boot space clear
What do you guys think ????
Hey Gaz
lol its 19" attached to a x5 (not mine unfortunatly)
Hi Apache
Your idea has the advantage that the two Targas are separated by the centre speaker. Its always been the clashing together of Targas that trashes them.
Seems a bit wasteful of space to put it dead centre though ??
Showme Showme pics :hyper:
there is only 2" under the centre cover i have a swb too and looked into all the possibilities in the car ,even constructing boxes to go either side of the centre tray.
most people mount there amps in the centre tray location.
there is enough room behind the passanger seat looking behind the black cover to build a custom box for an 8" sub imho but there isnt that much room behind the driver.
good luck in your ideas bud keep me posted on what you decide
Hi Apache
I'll take a pic tomorrrow with the targas in the boot :D
Helpful info Thanks Gaz
Im not going for a full out Amp display and Ill probably go for a single cone, as stereo works better at higher frequencies. So ATM the favoured spot is behind the passenger seat which I now know has approx 8" clearance
Cheers Bud
centre cover constructed with slimline amp
Cheers Bud
you will probably have to do a bit of fancy fibreglass work but take the passanger strut cover off and you will see it can be done. i just couldnt be bothered + i have never used fibreglass before lol
Hi Apache
Here are some pix mate.
First one shows Targa 1 in place
Second one shows Targa 2 in place
Third one shows them from inside with the tailgate down
I use an old towel and some foam bewtween the panels to help protect them.
I also use the straps to secure them down.
As for wasting space - it doesn't really bother me as
a) the sub can easily be removed if necessary and
b) in my case the Zed is only for pleasure use and as such rarely has much in the boot
Apache thanks for your input
Halfords also sell a tray insert for a DIN radio slot....... Not sure how much it is though.
£15 and its crap - Had one in my RX-7... The problem is that the plastic is cheap and brittle so all the clips etc snap really easily! Also, the inside has these annoying ridges so you can't really put much in it! :headvswal
Looks ok though...
