protoj ·
SHIT SHIT SHIT SHIT AND DOUBLE SHIT
Please phone me on 07968 586036, you need to talk to me before you buy a Z in Leicester.
Please say you have not bought a Zed in Leicester from the same fucking theiving clocking trader I bought my first one from
Glen.
