In memory of Mandy
polished plenium
can any 1 help please im changing my normal plenium for a polished 1 is there anything else i need to change when swapping them over? :wack:
dont forget the gaskets, and the throttle body gaskets, balance pipe o-rings
As fastredz has said but you may also want to change all 5 PCV hoses and PCV's and do a water bypass as it will make the whole job a lot easier
whats the benafits of doing a water bypass on the plenum please matey :confused:
doing the water bypass removes a load of small bore pipes from under the plenum, there must be a dozen joints under there, which could all go, also the pipe is so small bore it will get clogged up really easily. The water pipes were put under there (IIRC) to stop throttle body freeze in cold conditions, but it never gets cold enough here to warrant it
