anyone know about audi TT's?
the cars been stood for 2 weeks, starts up, abs, esp, & other lights on, checked the charge rate & its not charging, check the batt & its a cell down, ive replaced the batt, but still not charging? pressuming its the alternator, but being a modern car im unsure! anyone got any ideas about this? Theres no relitive fault codes BTW
thanks steve
Regulator / rectifier unit could be knackered?
Must say I don't know much about cars either - just bikes really. Good luck with it!
As with new commercial wiring systems sometimes faults occur when things dont power up properly like when starting and with a flat battery, I have seen all sorts of faults occur in the error memory, but actually they have been generated by improper powering up of the ECU's, have u tried disconnecting the good battery for a few minutes, then re-connect it. I used to get grief like that with multiplex wiring systems even although a 24 volt system, most modern cars have multiplex, maybee i am waffling but worth a try.
Cheers John Crisp
No, ive not tried disconecting the battery, i even kept the car powered up whilst changing the battery, i'll try the disconecting it, & see if theres any change, if not, i'll just fit a new alternator ££££!
thanks both for your input, steve
