Fail MOT test due to right rear driving light not working
Hi zxers,
I went in for MOT the afternoon only to realise the right rear light not working. Now I ave spent the last hour or so trying to rectify if but could not source. I put in new bulds, swap theleft ones for the right one still no luck.
However the break-lamps are working though.
Is there a fuse that control each side of the lamps?
thanks
Ade
Right you need to follow your back light wiring down inside the right inner wing and then you will find a little black box about the same size as a penguin bar :x: this is the relay and you will need to replce it bud ;)
Mine did the same and it took me foooking ages to find this box after stripping all the wires back cos someone said it might be a bad earth.....:nono:
Thanks for that, I did see the relay but never gave it a thought.
Ade
