can someone tell me??
where to get replacement bulbs for the z do halfords do em or am i gona have to find a website and get em delivered????????
cheerz replys much appreciated... :hyper:
Dipped beam I presume. Search on eBay for H3C or buy direct from Mike Feeney (MJP) in the traders section.
Luke at the Zcentre
You can also buy a normal H3 bulb and solder a wire to the base of it to make an earth. This is what i have done and works a treat. Better than paying £22+ for a set. If you search around you can find the instructions to do that, or the other mod when you attach a wire to the inner light housing on the small cross head screw. Its a bit more fiddly but if you cant be ar#ed soldring every bulb, it's a winner. Hope this helps bud.
[sIGPIC][/sIGPIC]
Will the H3C ones on ebay defo fit a Jap TT ???
Bulbs H1 - main beam ( 100w ok or 60w + 50 % brighter philips)
H3C - dipped, PIA Super White straight replacemient)
H3 - Fog, (60w + 50 % brighter type is OK)
Just found that from a previous thread matey. They should be ok :D
[sIGPIC][/sIGPIC]
cheers matey.
Think i will order some as dipped beam is as much use a pair of candles !!
