There is a guy who has assembled all the stats for tons of UK cars into an Excel spreadsheet and done some smart calcs and searching stuff etc. It means you can compare power to weight, torque to weight ratios etc etc. Have a look at :-
http://www.shaun.sheppard.btinternet.co.uk/durhamcruises/ukreccars.htm
This is the readme.txt that comes with it :-
The DervMan's DataSheet 3.2
Introduction
These brief notes will help you to understand what the
DataSheet contains and how to get the most from it.
Firstly, the DataSheet is in M$ Excel 97 format. If you
want it in another format, let me know. I will try my
best. Since I use M$ Excel 97, in any other format you
will lose some of the special features.
The DataSheet contains two types of data: that sourced
from magazines / brochures / others and the rest, which
is calculated. To save space, all of the data in this
DataSheet is a Value - i.e. if you add new cars, it will
not recalculate the cells.
By using values the DataSheet has gone from 3.4 Mb to
only 900 Kb.
Column Titles
S Special Select. Use this to help you select
cars with otherwise different characteristics.
N Nationality. The latest DataSheet contains
many American cars. V3.2 only contains a
token trio.
Make Do I need to explain this?
Model And this one?
Year Heh you must be kidding.
Eng The engine capacity, in litres.
Ig The ignition type (injection, mechanical, carb).
F Fuel type, petrol, diesel or LPG.
As Aspiration - NA (atmo), LB (low blow turbo), TC
(turbocharged), SC (supercharged), Hy (hybrid).
Cy Cylinders.
Va Total valves for the engine.
D Driven wheels (front, rear or all).
Ins Insurance Group (note these vary, and the highest
quoted is *usually* used).
MPG Either the Euromix or the Government Combined MPG
depending on the age of the car.
CO2 The CO2 output of the car.
RtV Retained Value after 36k / 3 years.
Sz Size class. 1 = city car, 1.5 = small coupe,
2 = supermini, 2.5 = medium coupe, 3 = small family,
4 = medium family, 5 = large family, 6 = small MPV,
7 = large MPG, 8 = small offroader, 9 = large
offroader. Used for sector comparisons.
Type See Sz, only expressed as a text field rather than a
number
Cl The vehicles power and torque class. The higher the
better. Gives a simple indication of performance.
Service What Car's 36,000 mile maximum service cost figure,
or a guestimate
Mph Vehicle's top speed.
0-60 Guess?
30-70 Where available, the 30 - 70 time through the gears.
PS Maximum power output of the engine.
Nm Maxiumum torque output.
Kg Quoted kerb weight.
Lts Quoted fuel tank capacity.
PW Power to weight ratio.
TW Torque to weight ratio.
WR Sum of the above two.
PSL PS per litre of engine capacity.
NmL Nm per litre of engine capacity.
OPL Sum of the above two.
VPC Valve configuration per cylinder.
Rng Car's 95% range at the Euromix figure.
TF Torque factor - the ratio of Nm to PS. As you get
closer to 1.0, so the engine feels peakier. VTEC
drivers note!
Lease Where available, the 3 + 35 / 36K lease cost figure,
Cost but note that these are *very* variable.
CPM The cost per month of leasing it - includes fuel,
(Lease) and insurance, excludes everyything else.
CPM Cost per month of owning the car, excludes finance
(Lease) costs and depreciation (at present but its coming!).
Value The DervMan's Value Rating. Measures cost per month
and Performance. Higher is better!
CO2 Measures the CO2 output against the performance, to
Perf get the most bang for your puff (so to speak).
Rel. Relative performance: wanna see how your Fiesta
Perf compares against the quickest car in the DataSheet
(currently the TVR Cerbera 4.5).
Perf Takes the PW, TW, maximum speed, 0-60 and 30-70
figures, shuffles them about a bit, assigns different
weighting to each one, substitutes where it needs to
and comes up with a "real world performance score."
Using The DataSheet
Filters
Do you know how to use Excel filters? Hope so.
Click on the black triangle in the grey box in the bottom
right corner of each cell. Select what you want to filter
by, for example, just Sz 1.0 cars.
Find
CTRL & F to find.
Calculations
I jealously guard the calculations behind the DataSheet!
But if you think something is misrepresented, please let me
know!
The CPM (Lease) and CPM (Own) figures use known insurance
details, fuel consumption, road fund, and service costs.
Whilst they have proved to be reasonable accurate in the
DervMan's experience, these are only an indication of the
cost of the car.
The Performance figure is not designed to show how quick a
car is on a track day, but how useable the performance is.
Most turbodiesels show up reasonably well here on account of
their high torque figures.
Comments, Suggestions, Beer Tokens, New Data
Send all comments, suggestions, beer tokens, or abuse to the
DervMan, at dervman@dotloose.com
If you have a new car, let me know at the above e-mail
address and I'll include it.
The DervMan
05/12/2001
No posts to show
