BOV Fitting
Help, first I can't get 300zx.org.uk to work to find a fitting guide for my Apexi BOV's. Secondly regardless of that I believe I know what I need to do but can't seem to find anyway to get to the rear bolts on the recirc's? I could probably get in there if the fan would come out but that wont come out because of the oil cooler in the way. I really don't want to move the cooler as it would probably mean draining oil etc... Any suggestions?
Unfortunately mate, you have to move the cooler (you have a UK car obviously).
Spray the bolts with lots of WD40 before hand and you should be able to unbolt the cooler from the bottom without disconnecting the pipes. You can then move it forward enough to get the fan out, then attack the re-circ bolts with a universal joint.
I had the same problems!:
http://www.300zx.co.uk/forums/showthread.php?t=35837
search is ur friend too mate , i asked the same question a while back but its a piece of pssssssssssss to fit !! Just undo the oil cooler bolts and bend brackets forward a bit to get fan out , no need to take lines off at all.
