Specifications of R33 GTR BREMBO pistons in the calipers please
as above peeps...
Im having some made up in stainless steel with the castelated tops to reduce heat transferal and was wondering if anyone knows the exact specifications of the two piston sizes within?
Thanks :duffer:
You'd need to know the caliper model number I reckon.
hhhmmm...
where would i find that out please...
I have found these two numbers on either side of the calipers...
20.5480
20.5479
and a 95 stamped on them
Isn't it just easiest to give the machine shop the originals to copy / measure?
If not, I guess brembo might give you the specs if you called them?
yer...spose so...
just wanted to make sure they were spot on as i dont know how much wear has occured on my originals....
I will give brembos a try but doubt they will divulge that sort of info as they will be loosing out on a sale..lol
Hes made them all from Stainless steel and just needs to put the castelated bit on the top of em now.
What with the DBA discs/Porterfield pads (ta smithy) and braided hose lines/5.1 fluid this will totally eliminate brake fade on track days....(gota fit the venting as well yet)
I asked myself this question though...
Why the hell did they make the pistons from alloy :xxx:
The material is a conductor..heat straight to the fluid to boil it :headvswal
I can only assume it was to take the heat away from the disc and pad and to save weight...but the alloy caliper makes up for this anyway.
also...theres steel bolts in the pad aligners..these corode quicker than you can say :eek:
A cost factor i think there.
I had painted my calipers with gold paint but they ended up coming out like a toffee colour and looked a bit poop considering the amount of money ive spent on them as mentioned to me by several people and felt ashamed :( ......
So their gonna be stripped down to the alloy again and then have them resprayed properly in a decent Gold...along with new shiny bolts.
So basically apart from the moulded alloy caliper everything will be new on them...better than new really coz their modded :duffer:
Got my C1 sideskirts done as well so im feelin pretty chuffed at the mo...
Thats saturday planned then
