Got vibration through car, it's not very bad but enough to be noticed and make high speed driving uneasy. It's definately coming from the back end and i've had the wheels balanced which seems to have reduced it. I know the car has had a recent prop shaft bearing but there is also a note on a previous service record that the prop shaft was suspected. To test, the prop shaft was removed and the car towed at 50mph - no vibration, prop shaft refitted - vibration present. Result - prop shaft worn.
I don't see how the prop shaft can be worn as it runs on a bearing and the bearing is new. Are there any other bearings?
Could it be something else?
