Colder plugs - autobox upgrade
Hi Forum,
Thanks for the recent advice re: my 92 JDM TT auto. Due to my long journey's 300+ miles 90-100mph (german autobahns of course) and the posts from the forum my car is now booked in for an autobox oil cooler upgrade while I get my EBC sport disc upgrade done. As I was talking to my mechanic he asked me if I wanted cooler iridium plugs fitted as I am also getting a full main service done (minus belts - they were done last month when water pump gave up - RIP). Transmission oil will be replaced, diff oil too.
Given my cars spec are the colder plugs a good idea, what will they do? Will they make Detonation less likely? allow the car to run cooler?
Spec:
92 JDM Twin turbo
Std Injectors
Std Turbos
Mines 'Light tune' ECU
Blitz Air intake
Blitz bost controller occasionally set to 10% additional boost
Injen Hard pipe kit
Stillen Intercoolers & ducts
Std Exhaust (but not for long - probably fitting mongoose soon)
HKS ALC shifter
UK spec rear wheels
Colder plugs are det protection. Basically the electrode on the plugs is one of the likeliest hot spots inside the combustion chamber that can cause pre ignition. NGK recommend going one heat range cooler for ecah additional 50-100bhp. I ran ZFR7F-11 copper plugs in mine when I upped the boost with no problems. Think the closest Irridium is BKR7EIX-11, but the projection is not so good.
Thanks I will get them and fit as soon as............
