smokey exhaust
can anyone please advise just bought my first zed and has a bit of a smokey backside. Does not smoke on start up or when driving it (normally or when i boot it) it only does it when it is sitting at traffic lights smokes really bad for about 15 secs then stops any advice would be great.john
Sounds like rear turbo seals. Hope not bud.
Could try replacing the PCV's and see if that stops it? also make sure your not over filled with oil.
thanks for the reply. as i dont no very much about cars can you tell me what the pcv's are and how hard it is to take the turbos off just so i now when the garage makes me cry
thanks
thanks
Turbo's off is an engine out job (£500 ish) then you need new/recon turbos (£1000 min)
The PCV's and pipes are on this diagram
http://www.courtesyparts.com/z32/oe_pcv.html
talk to MJP in the traders area and he will sort you with a set of new pipes and valves.
