In memory of Mandy
gearbox change
hi after buyimg my 300 tt auto i have heard a lot of bad stories about gearbox failure so iam hoping to do a manual swap could anybody tell me of all the parts i will need apart from the obvious (gearbox,pedals) thanx.
You'll need all these bits :-
Gearbox
Gear lever
New leather gear lever boot
Master cylinder
Slave cylinder
All hydraulic pipework
Pedal box
Flywheel
Pressure plate
Clutch disk
Throw out bearing
Front half of the propshaft
The plate that sits between engine & gearbox
Wiring loom for the reverse & neutral gearbox switches
Both clutch servo vacumn tanks + pipework
I would also recommend replacing all the cheap rubber bits like dust seals and so on, plus the gear shift bush and the gearbox rear mount & prop centre bearing.
Gearbox
Clutch master cylinder
Clutch slave cylinder
All pipework
Pedal box
Flywheel
Pressure plate
Clutch disc
Throw out bearing
Front half of prop
Plate between engine & gearbox
Wiring for neutral & reverse switches
Both vacuum tanks & valve
Trim to hold gear lever boot
Spigot bush
thanx
When doing this conversion, they do not normally bother with the servo assistance on the clutch as the unassisted pedal is apparently OK. It also saves a lot of work.
I had the servo assitance fail on my Clutch pedal..and it was a LOT stiffer.
I've had the servo assitance fail on my Clutch pedal..and it is a LOT stiffer.
yeah my clutch booster hoses went and the pedal was alot different and alot heavier , best keep !!
