tbars
hey all...any u read my last thread, about gettin a zed, i want a jap tt looking at tbar, i hear they do 2 + 2 and 2 seaters? i cant really find all the different specs if someone could let me know please would be a big help,
do the tbars leak as bad as the mr2s? ha..i seem to have to fix it every winter
.......................do the tbars leak as bad as the mr2s? ha..i seem to have to fix it every winter
Some have been known to leak but I have had no problems there.
I do clean the rubber seals with silicone oil each winter just to make sure though and I only ever remove the targas in the autumn or winter as I find it too hot late spring/summer.
Richard :)
Silicone grease seems to work for me too, I load it up every now and again when the weather deteriorates (quite often then).
But my a/c doesn't work, so my t-tops are off whenever the sun shines!
also what is the recomanded choice of year to go for,
for instance alot of people recommand getting a rev+ turbo mr2 coss it has a better head and block, the turbo holds its boost longer, better rear lights etc etc
Yes your welcome for the time we spent looking for the info for you :rolleyes:
A revision 2 or higher (August 1993) onwards are better, no tweed trim + some better engine parts (PTU ect)
Lol Its all politically correct here now. What takemetothepub really meant was...I understand you could be a slow typist and by the time you finished you found two replies :)
Ive had 3 Zeds in 6 years and never had a leaky roof.
I've had my zed about 6 months now, and haven't had any problem with this. It's been outside in all kinds of weather as I'm sure you can imagine. I do have a cover for it that I use quite a lot, but that's more because after 3 hours cleaning it I don't want it instantly dirtied by foul weather, than to keep the water from leaking through the t-tops. If you haven't got a garage that might be worth a thought if you're particularly worried about it.
I've *never* noticed any water coming in whilst driving, even when it's been hurling it down on the motorway.
No I meant people should have common manners. If someone helps you then say thanks :mad:
