300ZXTT versus Supra TT
Pooopra saw me on a side road and speeded past, I came out of side road and soon caught up, Poopra tried his best to get away but I was firmly stuck to his arse for 4-5mins, there was no opportunity to overtake :mad:
Then he turned of onto a small dead end cos I think he had enough, looked slightly tuned with an exhaust, can't understand what all the fuss is about Poopras :D
As I couldn’t find the damn edit button, I have to post a new reply :p Just confirming my thoughts, the Convertible was only shipped as a n/a, right?
not toplesses one
Yep convertible Z, does it have exactly the same engine as the normal n/a?
Yep, All Convertables run Standard NA Zed engines.
Except Topless's ,as he has been clever with a spanner and its now Turbocharged
Hmm, that I don't know.
Okay :) Btw, not that this really fits under this thread, but what are the top speeds of unmodified (with speed restrictor removed) TTs and N/A's?
Any excuse for a bit of whoring! :rofl:
About...
NA - 145mph
TT - 170mph +
About...
NA - 145mph
TT - 170mph +
Okay, thanks. I've been thinking about that for a while but haven’t seen any statistic about that before :)
why is there such a difference in speed in relation to gearing
I meant between the Twin Turbo, and non turbo :)
:p
:p
i knew that i just want to know why is there such a difference between the two i would have thought the na would have been able to reach at least 155
Because it's only 220BHP :p I'm sure if you upped the power to 280 BHP then they'd be closer ;)
Simply a matter of aerodynamics over power.
Bigger BHP doesn't always mean better acceleration (that's more down to torque) but it will give a much higher top speed in the same car. Both N/A and TT are aerodynamically similar (although owing to the deeper front spoiler the TT is slightly less slippery). They would both hit the "wall" of air at similar speeds which holds the car back but the TT has nearly 60bhp (stock) over the N/A which gives it more push against that "wall of air"
I have read that an N/A should reach 148 in stock form.....
....but I don't know about the differences in gear and final drive ratios of each car.
Richard :)
My mk2 8V Golf GTi done 130 max, well chuffed at the time.
:smash: :smash:
me and the missus had a similar thing happen, but i was just driving along at 50-60 and one pulled up to my window and dumped of his bovs, so i droped into third (he must have to) and under took him and pulled away in every gear, got stopper at some trafic lights and done the same again, i slowed down and he pulled along side and gave me the thumbs up. nice that.
