Standard Relay
Anyone know what wires go to which pins on a standard relay
I have -
Pin 85
Pin 86
Pin 87
Pin 30
one is Earth, one is supply 12V, one is switch, and one is supply to device.
Here is the info for bothe 4 and 5 pin relays
4 pin relay
86 Coil connection
85 Coil connection
87 Load ( eg. accessory,lights,horn etc )
30 supply ( can be +12 v or earth circuit switch depandant)
5 pin relay ( change over relay )
86 Coil connection
85 Coil connection
87 Normally open
87A Normally closed
30 Supply ( can be +12 v or earth circuit switch depandant
Hope that helps
Jeff TT
Cheers Jeff, Im wiring up a relay for airhorns so I need a +ve supply of 12v.
the horn works but blows the 10A fuse if used for longer than 2 secs.
so its -
30 - +12ve from Battery
87 - to +12v horn.
86 - from fusebox +12v (switched) that supplies horn at minute.
85 - Earth.
